front subframe mounting
I have decided to rebuild my scamp using a 2 bolt fixing front subframe.
My question is with regard to the loose spacer between the subframe and the body.
Is the spacer just the standard spacer or was a thicker spacer provided with the kit?
If a standard spacer was used I have only have one and would need another one - whilst I could make one does anybody have a spare one for sale?
Roger Dudley
Roger Dudley
rogerd- Number of posts : 5
Job/hobbies : surveyor/ autotests trials and cars
Registration date : 2010-11-20
Sorry to confuse the issue - I am going to use an old subframe with 4 bolt fixing (2 either side)
On the other scamp I have there is a thick (much thicker than the standard spacer I have) spacer between the subframe and the underside of the Scamp chassis.
I am interested to know whether I should fabricate some thick spacers or whether the standard mini thinner spacers would normally have been used.
Roger
Roger
Re: front subframe mounting
Thanks very much for the photo and information - that is exactly what I needed to know.
thanks
Roger
thanks
Roger
That's handy. This has answered the exact same question I was going to post
» subframe mounting
» Front Subframe.
» subframe for mk1
» Front Subframe Wanted
» Wanted. front twin bolt front sub frame.
» Front Subframe.
» subframe for mk1
