subframe for mk1
subframe for mk1 Empty subframe for mk1
Post  cliff owen on Fri Feb 13, 2015 10:13 am
Will the mk1 only take the pre 76 front subframe, or is it possible to for a single bolt one?
cliff owen
Number of posts : 23
Job/hobbies : driver/mechanic
Registration date : 2014-11-05
subframe for mk1 Empty Re: subframe for mk1
Post  SUMB on Fri Feb 13, 2015 6:49 pm
Anything is possible - it's a Scamp.
Angle grinder - drill - welder - some steel
Job sorted.
subframe for mk1 Empty Front subframe
Post  Minivanman on Sat Feb 14, 2015 9:30 pm
When I got my MK3 it had an early subby with the four tower bolts, I changed it to the Single bolt mounting.
Minivanman
Number of posts : 84
Post  Steve G on Thu Feb 19, 2015 12:14 pm
I asked about this for my Mk2. It was suggested that I could bolt on the missing rear sections of the subframe using parts cut from an early one. The single bolt tower mounts might be a bit more tricky depending on how the chassis is made. I've seen pictures of what someone has done with a MK2 and all they did was drill a big hole on the chassis box section and use the standard big bolt. I don't know how the MK1 chassis is made in the mount areas but it might be best to re-enforce the area a bit and you might need some spacers on the big single bolts.
If you get really stuck I have an old Mk1 subframe I could cut some bits off. It isn't very straight though which could cause problems.
I have just looked at the pictures of your car on Facebook. Te box section used for the tower mounts looks a bit wider than the Mk2 so you should just be able to make the hole bigger that already there. What I was suggesting above depends on if you want to keep the subframe solidly mounted or want to use the later rubber mounts.
Post  Ferretboy221 on Thu Feb 19, 2015 9:16 pm
My mk2 was drilled for both single and twin bolt, used an old 2 bolt setup in the end mounted mine completely solid and never had issues and you get fantastic feedback....but the road noise/feed on bad tarmac is awful. .....my new mk1 frame is single bolt but Andrew has added more support to stop the box twisting than an original mk1 would have had.
Post  Steve G on Thu Feb 19, 2015 10:14 pm
Will you solid mount yours or use the standard rubber mounts ? I made up solid ones for my Mini as you could see the subframe moving when you rocked the steering.
Post  Ferretboy221 on Thu Feb 19, 2015 10:38 pm
poly mounts compromise between the two solid is brill on short/medium drives but after a long day can get v grating
