Suzuki based Mini Clubman Estate
Here is your chance to own a very unique and very well built 4x4 Mini Clubman Estate based on a Suzuki SJ.
The chassis and running gear is all Suzuki SJ410 which is a 970cc engine, 4 speed gearbox and selectable 4 wheel drive.
The Estate body has been very well fitted to the chassis with extra care taken to make sure the wheels line up with the arches and actually sit within them.
The engine has been converted to run on a 1 1/2" SU carb and has the correct needle and spring fitted and is running great.
The car has recently had a Mini heater fitted inside and also a brand new radiator.
The car is taxed until November 2011 and has MOT until August 2011
The car is based in Derbyshire and has to be seen to be appreciated.
Yours for only £1,500
Will add some more pictures soon.
Gray- Number of posts : 65
Job/hobbies : Engineer / Mini's and motorsport
Registration date : 2009-07-06
Re: Suzuki based Mini Clubman Estate
Why are you selling Ian
Simply because we aren't using him and would rather pass him on to somebody who will give him the use he deserves.
I've done all the work on him that we wanted to and is running great so seems a good time to pass him on.
» Clubman Estate Register charity Thong Run 2009
» SJ410 Suzuki with MOT
» McCoy...... Mini based...........
» mini based kit car adverts
» 1970 GRANTURAYAK Mini based kit car ( SCAMP ) ?????????
