I miss my mud fix!
I miss my mud fix!
Whilst looking for Nettie's Florence tonight in old previous events I came across this picture of me having a great time at the Telford Picnic site
Re: I miss my mud fix!
That does look fun. I'm not so sure about getting quite so close to the mud though you must end up carring a lot round inside !
I used to go on family trials with a friend who had a Range Rover and that was fun, even took my Transit once but the poor thing was so rusty I didn't want to finish it off. It was so high you only got muddy if you had to get out.
Whats that on the bonnet ?
I was always knocking off the exhaust on my 1st mk2 when off-roading / greenlaning so I built my next mk2 with off-roading in mind. I turned the cast iron exhaust manifold upside down once I'd sawn off the inlet, used an after market ali inlet manifold, bolted a silencer under the front bumper and connected the two via length of flexible exhaust pipe, hence the hump on the bonnet. I later removed the hump and replaced it with a large box so I could lay my camping stove on the bonnet (saves lugging a table round with you). A piece of perforated plate covered the silencer to stop anyone burning their legs.
Brilliant, there was a picture of another with the exhaust sticking straight up through the bonnet.
if you had put a hot plate of some sort on it you could have cooked straight on it !
My uncle used to stuff foil wrapped potatoes in his SD1's exhaust manifolds to cook on long journeys, but that getting off topic.
Have you still got a Scamp other than the MK1 ?
