Food for thought ?
Food for thought ?
What's NASA up to now? The closer we look at this mad science experiment, the more we can see a bigger, hidden ugly picture.
Our Moon is extremely important to our Earth and our survival. It acts as a flywheel/stabilizer for Earth's non-spherical shape. Simulations show that without the Moon oceans would become dead zones. Tides would no longer ebb and flow, which are vital to numerous forms of life world wide. Many sea turtles, crabs and other animals rely on tides for their survival. This ties directly into our food chain, too.
Apollo missions forty years ago left retro-reflective mirrors on the Moon, to measure its distance relative to Earth. Lasers send out a precisely timed pulse, and can measure the distance to within a fraction of an inch.
Now the National Science Foundation is going to cut funding for the McDonald laser ranging station at Ft. Davis, Texas.
Something is very wrong here.
If NASA wanted to continue the project, which they should be doing, they could tell the NSF not to cancel this project. But apparently NASA is remaining silent. Just as they have remained silent about numerous Mars discoveries being made by the ESA Mars mission.
In just a few months, NASA will EXPLODE a TWO TON bomb on the Moon. They claim this is in the interest of paving the way for colonization, and "to find water." So what's the problem? Here are just a few of the facts that come to light:
1. Exploding a bomb on the moon will displace several miles of Lunar material according to what NASA claims will happen.
2. The displacement of lunar material will follow Newton's law about equal and opposite reaction. This means that an equal force will be exerted on the Moon to match the force it takes to eject miles of material. No one can actually predict what will happen, just as NASA failed miserably predicting the results of another experiment. In a previous mission, a NASA spacecraft fired a high velocity copper warhead penetrator into a comet's core. The results were not what they expected. This is because popular science theory really believes comets are dirty snowballs. Instead, the actual results were already predicted by the electric universe theory. Comets are not dirty snowballs which is something many of us already knew. Yet again, NASA refused to use common sense and look at theories based on real evidence and science, such as the electric universe theory.
3. If the McDonald Moon ranging project is cancelled, no one will be able to measure the displacement of the Moon caused by the explosion. Perhaps this is the idea by cancelling the project.
4. Exploding a bomb on the Moon is against all international laws and treaties. NASA doesn't own the Moon and they never will, and as such have no right to instigate such madness. This madness is on a par with the utterly insane space elevator.
5. Last but not least is the water issue. This is one follows yet another big lie. Almost every book about our solar system claims it is nearly a perfect vacuum. So how does water behave when exposed to a reduced atmosphere? The speed it evaporates (sublimates) is in proportion to the amount of atmosphere present. If a window blows out of a plane at 50,000 ft. water and blood will boil. And that's not even in a very good vacuum.
And here's what it all comes down to ­ water disappears completely in a vacuum. Therefore, the idea of NASA finding water on the Moon by exploding a bomb in a vacuum on the Moon is utterly ridiculous. Heat from the bomb combined with the vacuum will flash-evaporate any trace water so fast it cannot not be measured. No two ton bomb has ever exploded without generating tremendous heat, and this heat will blind infrared sensors. Long before the sub-lunar surface cools off to take a reading, any water will be long gone. So the idea of using a bomb to find water is wrong on many levels.
There also remains an even bigger and more important question ­ what happens if they disturb the Moon's orbit? Few people alive today remember what NASA said when the spent Lunar Landers were ejected and crashed into the Moon. NASA stated that the seismograph instruments the Apollo crew left behind showed that after a Lunar Lander crashed into the Moon, that it "made the Moon ring like a bell for more than 30 minutes." Would this same thing happen if the Moon were made of solid rock?
The Lunar Lander ascent stage weighed just 10,334kg. which is about the equivalent weight of an 11 ton truck.
The mass of the Moon has been calculated to be 7.36 1022 kilograms. That's a 7.36 followed by 22 zeroes.
So how could an 11 ton spacecraft, which weighs even less on the Moon because gravity is 1/6 that of Earth - make 7,360,000,000,000,000,000,000 kilograms of rock ring for half an hour? Who could believe this?
This appears to strongly prove the Moon MUST be hollow. And if the Moon is actually hollow, it will take far less to disturb its orbit than anyone currently realizes. How many millions of kilograms of force will bombing the Moon generate? We are not being told that figure.
Disturbing the Moon's orbit may cause tidal waves and quite possibly Earthquakes in many zones around the Earth where edges of tectonic plates are already at or near the breaking point of sliding. The stress caused by a sudden shift in the Moon's gravitational pull could be a serious catastrophe. Who knows what it might do to the Yellowstonesuper-volcano which is already heating up and has made larger areas of Yellowstone park unusable.
And if the NASA experiment goes badly wrong (like most NASA projects do the first time NASA tries them) what do they think countries of the world will do? Send a bill to theUSA for damages? Perhaps NASA will do what they usually do. Lie their way out of the problem.
Is bombing the Moon really worth risking orbital stability, killer Earthquakes and the futures of countless life-forms on Earth?
Or creating an irreversible disaster?
Re: Food for thought ?
Martin, is this a wind-up? If you posted nonsense like this on a science forum it'd be regarded as troll droppings.
Bob it was taken from an internet site called soomething like dontbombthemoon.com - we all take what we see in the media as the truth i.e. weapons of mass distruction etc, it does us all good to question things and a quick peruse of the conspricy theorists and tree huggers now and again brings thing into perspective don't you think
It was on the news yesterday, Nasa bombed a crator (?) with a following camera drone to find any water sent up in the blast debris.
As you said well dodgy as they are more or less using the same blast method to knock comets off their course and away from earth.
Well I think best leave well alone. Our planet and solar system have done well, and are still doing well after all the things mankind have done in the pass 100 years or so...The oceans are getting a bit warmer and the icecap in melting, but messing around with planets is another story...It could end our scamping in many years to come...Then we will be f*cked, thats if the wa*kers don't stop us first...
Thats not a dig at you Martin..
RICK- Number of posts : 232
Job/hobbies : Green laning
Registration date : 2008-05-22
» Not a Scamp but rare Stimson
» Just thought i'd mention it!
» Having got a scamp yet but saw this and thought of you guys
» A food challenge for hungry Scampers?
