Help needed..!!
orbski
Help needed..!!
Has anyone got..either to sell to me..or that I can borrow to measure up...a set of radius arm extension plates?
Re: Help needed..!!
Sorry if i'm wrong but are they the adjustment plates (camber etc)?
If yes I do have some.
Re: Help needed..!!
Thanks, but I'm after these babies......
Re: Help needed..!!
That's a rather natty hi-lo set up Jono, what vehicle are we looking at the underside of?
Re: Help needed..!!
Anderson Cub...
Re: Help needed..!!
Hi Jono,
I've PM you....
Dave
I've PM you....
Dave
muttley- Number of posts : 397
Re: Help needed..!!
It's interesting to note that the Anderson Cub extensions only extend the wheelbase. The Andrew's Scamp ones also raised the ride height by being angled downwards.
If i remember correctly they increase wheelbase by 3" and height by 1", though i may be wrong.
Re: Help needed..!!
Steve Taylor made his own trailing arms out of box section didn't he
Re: Help needed..!!
Martin & Nettie wrote:Steve Taylor made his own trailing arms out of box section didn't he
Yep, and a pair are sat in my garage. Steve Edmonds also has a pair, maker unknown, that are actually better than the Steve Taylor ones.
Re: Help needed..!!
..box section? Did they have some major league wall thickness and/or bracing. Post a picture, would you?
Cheers, Jono
Cheers, Jono
Re: Help needed..!!
The guy who built my Mk2 extended the trailing arms two inches by cutting and inserting a length of gas pipe... which sounds extremely dodgy, but they're brazed in, the alignment is correct and the MoT examiner didn't remark on them.
Unfortunately, without booster springs the extra leverage caused the back end to sag, and anyway the pivot bushes were past it, so I've replaced the arms with normal length ones, with some misgivings as the wheel isn't now central in the arch. However this won't be a problem if the intended 6-wheel conversion ever comes to pass.
Re: Help needed..!!
Jono wrote:..box section? Did they have some major league wall thickness and/or bracing. Post a picture, would you?
Cheers, Jono
Run away from Steve's 40mm box trailing arms Jono and take big steps! Sarah Irish has a pair on the back of her Scamp. The deflection AND twist in the trailing arms is actually visible, camber and toe changes whilst driving!
If i was going to fabricate a set I'd go down the route used by autograssers. Harry Hockley makes one's for Rally cars that look easy enough to copy.
http://www.hh-ms.com/HHMS_rear_independent_sus.htm
Re: Help needed..!!
They look very similar to the ones that Steve Edmonds has. Much more substantial than my Steve Taylor ones.
Re: Help needed..!!
As is the price tag...Much more substantial
Re: Help needed..!!
Rum Tum Tugger wrote:As is the price tag...Much more substantial
Who said anything about buying them? I'd make my own.
Re: Help needed..!!
Which brings us back to the top again
Re: Help needed..!!
...now sorted, with many thanks to Dave. Cheers
» Needed for the Scamp picnic James
» A bit of help needed
» Tyres needed for Mk1
» LDV parts needed
» Old age and poor memory -Help needed
» LDV parts needed
