Engine Identity (or should that be "Identity Fraud?")
minibuger
Clifford
Having now established that my Scamp has the wrong rocker cover, it set me wondering just which engine it has.
The engine number tag is missing but the V5, for what it's worth, gives it as 9FDSAH.5075 and says its 998cc.
I've looked this up on a few websites and one shows it as being a 1071cc Cooper S, whilst two others say it's a 998cc. Mk.II Morris Cooper, all say it should have "Closed Circuit Breathing". Now, the V5 gives the make as Austin and, as it has front drums, I know that at least these weren't Cooper donated.
Are there any tell-tale signs that would give an indication as to what it really is?
As always, any comments much appreciated.
Clifford- Number of posts : 19
Job/hobbies : Retired Engineer - Classic Cars and Music
Registration date : 2009-04-13
Remove the rocker cover if it is a cooper head ,it will have 2 springs per valve and there is also a number at the back of them on the casting and you could also try look at the gear box cast number see if it a cooper one .If it is a cooper head it may have been put on a standard block ,the only real way to find out is to strip it and check the part numbers ie crank,conrods,cam .
Re: Engine Identity (or should that be "Identity Fraud?")
As the previous post says there should be a casting number on the head.
12g295 or 12g206 are 998cc/997cc cooper heads.
12g202 is an 1100cc head.
CAM4810 is a standard head used from 87 onwards and is lead free.
The earlier heads vary but most start with 2A or 12A
hope that helps.
hope that helps.
Just found a brilliant website with most of the British Leyland engine numbers,yours is pre 1970 and is a cooper 998 engine with 9.1 compression(well it was when it was new).The website is www.mgcars.org.uk/mgccz/technic/codeseng.pdf hope this of some help.
At least that is what it should be according to your logbook.You can get a new engine plate made, I have seen them at most of the Mini shows.
wezgit daan saaf wrote:Just found a brilliant website with most of the British Leyland engine numbers.
That sure is a Brilliant site.
I am still confused hehe mine is 99hb81p it says 99hb82p is automatic mine is manual
someone went to a lot of trouble.
Last edited by m3prq on Sun May 17, 2009 4:40 pm; edited 1 time in total (Reason for editing : to add my engine number)
m3prq- Number of posts : 108
Job/hobbies : kitcars 1980 to date
Registration date : 2008-07-13
It''s a Cooper Head Alright
Thanks for all this advice, the casting number is 12A185 and it has the double springs so it's certainly a Cooper head. Not 100% convinced about the rest of the engine though, especially considering it doesn't have closed circuit breathing which, according to the V5's engine number, it should have. So, quite possibly a cooper head on a standard block, or perhaps even an older Cooper block. I'm not about to strip it down further just out of curiosity but obviously something to bear in mind for the future.
Whereabouts might I find the gearbox casting number? In the hope of shedding a little more light on things.
Hi the gearbox number is behind the oil filter if i remember right it should have 22g190 or 22g 333 ? in it if its a cooper box .If its not been run for a bit i would change the oil seal in the timeing chain cover and see if its got a twin row chain on it like the coopers did .
On alot of the earlier A series engines they used to cast the cc in the side of the block,might be worth looking around the back of the engine underneath the side covers.
Gearbox Casting Number
OK, back on the case now after a most unwelcome break.
The number cast on the gearbox, by the oil filter, is 22A1288.
Does this mean anything to anyone?
In lieu of a sensible answer my guess is that your engine was made on the 22nd April 1288.
Hmmmmm ......... 12th April eh? There was me thinking it might have been a little earlier than that, possibly by as much as eleven days.
minibuger wrote: (none s, type b box ,alloy remote type) ??????
Not quite sure what this would mean, especially the 'none s' bit.
Don't seem to be getting very far with this quest. I've now read, in the Haynes Manual, that all 998cc engines had double valve springs! So perhaps it's not a Cooper head after all, although I've also found out that it's got a Cooper S dizzy which you can no longer get points for!
Aaaaarrrrgghhhh ! There was me loving my Scamp because it's so simple and basic!
Its not a cooper box ,but it has the alloy type gear remote like the cooper's .type A box being the wond type ,and the later rod type box is a C type from 73 on.Also if the remote bolts to the box with two bolts for the bottom in to the remote its a Austin 1100/1300 box with a longer remote as all the mini remotes bolted from the side You should be able to get a set of pionts for Mini Spares?
Thanks for explaining that, it all make sense now and certainly ties in with my box.
As for the points, it was Mini Spares who told me they weren't available any more and suggested I try ebay. There I found several sellers had Cooper S points for about £15 a set whereas normal points go for £2.50. I'm going to try some adaptations, although as far as I can tell, the main difference with the Cooper S points seems to be the spring strength.
I will ask my local parts shop for you and get back to you as thay carry lots of old parts .
Isn't your dizzy just a Lucas D25? surely there the points are interchangeable with something else?
It might be worth trying Moss, speedy spares or Rimmer Bros as an alternative.
Dizzy looks like a standard D25 but it's serial number is 40819, as fitted to the 970, 1071 & 1275cc Cooper S, and it has no vacuum advance. I've bought a standard set of points so will see if they fit at the weekend.
They fitted D25s to everything from Land Rovers to MGBs so you should be able to get a set of points for it. I even think I have a set in my old MGB spare box if you're desparate.
Hi all, Well I've established that standard points fit OK but the spring in the old set is definitely stronger than the new set, although I can't see it making much difference to me, I assume it might have some advantage at high revs though. My concerns were raised when I looked up the dizzy number in Haynes and found it was from a Cooper S. Mini Spares list a set of points specifically for the Cooper S so that's what I asked for. When told they were no longer available I assumed the worst and thought a dizzy change was the only option. Panic over.
In my endeavour to give my new Scamp a thorough service, I have however discovered a bit missing from the oil filter assembly. There should be a plate that applies the spring pressure to the element to keep it sealed up against the mounting bracket. This plate was missing so the oil could bypass the element. In effect, no oil filter. Plenty of sludge in the bowl though, only hope it hasn't caused too much excess wear or premature damage. I found a huge washer which seemed to fit perfectly so will probably become a fixture.
Next problem (and next post) - Timing.
» Engine and subframes
» New beach attraction called "Dinner in the Sky"
» Engine Changes ?
» "and then the fight started"
» Ebay ......"scamp".........
» Engine Changes ?
