Side/indicator lamps
Side/indicator lamps Empty Side/indicator lamps
Post  Minivanman on Mon Oct 21, 2013 11:33 pm
Stupid question time again,
looking forward to the appearence of the front of the car, was wanting to fit round side/flasher lamps that I thought came from land rover but on checking their website they dont do a combined unit, so what do you suggest for front flasher/side lamps?
Minivanman
Number of posts : 84
Side/indicator lamps Empty Re: Side/indicator lamps
Post  Mike W on Tue Oct 22, 2013 8:23 am
Hi, I have Austin 1100/1300 indicator side lights on my mk2,they look pretty good
Mike W
Number of posts : 29
Job/hobbies : Self Employed
Registration date : 2011-12-17
Post  John on Tue Oct 22, 2013 9:21 am
I think the austin 1100 units are oblong . The Morris Minor 1000 and MG 1000 amongst others used  a round one. Try http://www.ebay.co.uk/itm/MORRIS-MINOR-SIDEINDICATOR-LIGHT-UNIT-/171093517498  but check others as well, ensure you buy whole unit (if thats what you need) and not just the lens. Minor 1000 specialist may also be able to supply new ones? There are also gasket/seal kit available for these lights on ebay. Happy hunting.Smile
JUST SPOTTED this http://www.ebay.co.uk/itm/111188701962?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D111188701962%26_rdc%3D1        (one NEW, one S/H with new lens)   ENDS 23/10 19.14 so if you want them go get. Good Luck. If you are not interested in bidding for these please say so on here. I might then put a bid in myself, but will not bid if you are going to.
Last edited by John on Tue Oct 22, 2013 12:13 pm; edited 5 times in total (Reason for editing : JUST SPOTTED THIS. then added other text several times!!!!!!!)
John
John
Number of posts : 160
Registration date : 2009-01-22
Post  Rum Tum Tugger on Tue Oct 22, 2013 10:16 am
The unit fitted to Morris Minors (and various stablemates) is Lucas part number L632.  Used, repro & new old stock seem to be readily available, but not cheap.  Europa Spares have some fancy mix-and-match round LED lamps with separate outer rings, at even fancier prices.
And if money is no object, there's always this.
Side/indicator lamps Empty Re Indicators etc.
Post  NG Guy on Tue Oct 22, 2013 11:02 am
If you want to go the kit car bits route, rather than original Mini bits, then Car Builder Solutions is also worth a look!
If going Mini or Classic Car route try Somerford Mini Ltd, based in Chippenham Wiltshire.
Regards NG Guy
Last edited by NG Guy on Tue Oct 22, 2013 11:13 am; edited 1 time in total (Reason for editing : Omissions)
NG Guy
Number of posts : 174
Job/hobbies : NGs, Tarot, Retired Tech Author
Registration date : 2013-10-02
Side/indicator lamps Empty side/indicator lights
Post  Minivanman on Tue Oct 22, 2013 2:33 pm
John wrote:JUST SPOTTED this http://www.ebay.co.uk/itm/111188701962?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D111188701962%26_rdc%3D1        (one NEW, one S/H with new lens)   ENDS 23/10 19.14 so if you want them go get. Good Luck. If you are not interested in bidding for these please say so on here. I might then put a bid in myself, but will not bid if you are going to.
Thanks John, Ill try and bid on these on "E" bay
Minivanman
Side/indicator lamps Empty side/indicator lamps
Post  Minivanman on Wed Oct 23, 2013 7:30 pm
Success: 1 pair of sid/flasher lamps purchased for £25.00 plus postage, result Very Happy Very Happy
Should maybe name this Scamp after "E" bay considering that's where all the parts seem to be coming from lol Cool
Minivanman
Post  John on Wed Oct 23, 2013 11:27 pm
Well done that man. Now all you have to do is fit them.Smile
John
John
Side/indicator lamps Empty side lamps
Post  Minivanman on Thu Oct 24, 2013 12:32 am
John,
That's a long way off as I've started from the rear of the vehicle, by rebuilding brakes suspension etc, the lights were looking to the future about cosmetics and as they were available and will keep for a later day. Probably see them next week even cheeper.
Minivanman
