» Any takers - convert your Scampby Mk3rob Tue Apr 17, 2018 1:47 pm
» Mk2 on Ebay Q***ANJ
by Rum Tum Tugger Tue Apr 17, 2018 8:45 am
» Mk2 on Ebay - Essex
by Mk3rob Sun Apr 15, 2018 2:09 pm
» NOS Spitfire fuel tank for sale
by Rum Tum Tugger Tue Apr 10, 2018 7:50 am
» LAUGHTON SHOW
by wezgit daan saaf Fri Apr 06, 2018 5:31 pm
» Garden find
by Rum Tum Tugger Wed Apr 04, 2018 4:33 pm
» Coffee / Tea debate
by Rum Tum Tugger Sat Mar 31, 2018 8:17 am
» New MoT rules from May 08
by Mk3rob Thu Mar 29, 2018 10:30 pm
» Mk3 project oop norf
by Rum Tum Tugger Thu Mar 29, 2018 9:58 pm
position of oil cooler
Page 1 of 1 • Share •
can anybody tell me if i can get away with fitting an oil cooler on the underside of the slap panel (box section) of a mk2 so the oil pipes go in the bottom of the cooler & not in the top like you normally see. the reason i ask is the the front panel is filled in on the bottom & there are slats on the top so would make an ideal place.
Mr Shiny- Number of posts : 57
Job/hobbies : Garden Maintenance / Scamps
Registration date : 2009-11-23
Oil cooler
I have my oil cooler at the top of the grill mounted off the top cross piece, but I still have the pipes going in at the top. Once I'm back home I could post some pictures if that helps.
red_leader- Number of posts : 181
Re: position of oil cooler
.red_leader wrote:I have my oil cooler at the top of the grill mounted off the top cross piece, but I still have the pipes going in at the top. Once I'm back home I could post some pictures if that helps.
i would be very grateful
cheers
Going to be quite hard to bleed it if the pipes are at the bottom and it'd be impossible to pre-fill it before connecting it to the rest of the system. Could you make some extension brackets to allow it to be mounted with connections on the top?
Oil Cooler
It will be Sunday or Monday before I can take some pictures.
cooler fitting.
Iknow its not as high as you are proposing but this is where mine was fitted...it is a 13 row mocal cooler with uprated pipework (the standard stuff that came was like garden hose). to 3000 psi rated hydraulic hoses.
OIl Cooler
red_leader wrote:It will be Sunday or Monday before I can take some pictures.
Sorry forgot will take pics
Oil Cooler
I welded a couple of plates to the oil fittings and then bolted these to another couple of plates welded to my Scamp.
