position of oil cooler
position of oil cooler Empty position of oil cooler
Post  Mr Shiny Thu Sep 27, 2012 8:43 pm
can anybody tell me if i can get away with fitting an oil cooler on the underside of the slap panel (box section) of a mk2 so the oil pipes go in the bottom of the cooler & not in the top like you normally see. the reason i ask is the the front panel is filled in on the bottom & there are slats on the top so would make an ideal place.
Mr Shiny
Number of posts : 57
Job/hobbies : Garden Maintenance / Scamps
Registration date : 2009-11-23
http://www.ph-services.net
position of oil cooler Empty Oil cooler
Post  red_leader Thu Sep 27, 2012 9:00 pm
I have my oil cooler at the top of the grill mounted off the top cross piece, but I still have the pipes going in at the top. Once I'm back home I could post some pictures if that helps.
http://www.scampownersclub.org.uk/
position of oil cooler Empty Re: position of oil cooler
Post  Mr Shiny Thu Sep 27, 2012 11:20 pm
red_leader wrote:I have my oil cooler at the top of the grill mounted off the top cross piece, but I still have the pipes going in at the top. Once I'm back home I could post some pictures if that helps.
i would be very grateful
cheers
Mr Shiny
Post  OSR Fri Sep 28, 2012 12:41 pm
Going to be quite hard to bleed it if the pipes are at the bottom and it'd be impossible to pre-fill it before connecting it to the rest of the system. Could you make some extension brackets to allow it to be mounted with connections on the top?
position of oil cooler Empty Oil Cooler
Post  red_leader Fri Sep 28, 2012 8:18 pm
It will be Sunday or Monday before I can take some pictures.
position of oil cooler Empty cooler fitting.
Post  Ferretboy221 Thu Oct 04, 2012 12:28 pm
Iknow its not as high as you are proposing but this is where mine was fitted...it is a 13 row mocal cooler with uprated pipework (the standard stuff that came was like garden hose). to 3000 psi rated hydraulic hoses.
position of oil cooler IMG_0859
position of oil cooler Empty OIl Cooler
Post  red_leader Thu Oct 04, 2012 6:39 pm
red_leader wrote:It will be Sunday or Monday before I can take some pictures.
Sorry forgot will take pics
Post  red_leader Thu Oct 04, 2012 7:08 pm
Post  red_leader Thu Oct 04, 2012 7:09 pm
I welded a couple of plates to the oil fittings and then bolted these to another couple of plates welded to my Scamp.
