Bottom Arm Dimensions
Its only me again...
This could be a quick question, or not as my questions go...
Front Suspension, Bottom Arm...What does a "Standard" bottom arm measure from the centre of the rubber bushed bore to the tapered bore for the swivel pin ?
This may sound like a stupid question, but Walle has got adjustable bottom arms & tie-rods. The length of the bottom arms was slightly different from side to side to take into account my previous skewed subframe .
If i know what the standard length of the bottom arm is, i'll have a starter for 10 when i start to assemble the suspension.
Cheers in advance,
Cheers in advance,
Re: Bottom Arm Dimensions
Sorted,
For future reference the standard length is 10.2" or 259mm.
