rubber cone compresses needed
Hi
Does anyone have a cone compressor tool Metric version ?
Please could I borrow during the coming week?
as close to Shropshire as possible
Thanks Mikescamp
Thanks Mikescamp
mikescamp- Number of posts : 46
Job/hobbies : IT/scamping,planting
Re: rubber cone compresses needed
yes please Chaz
I was hoping to get them in before stourport but not much time left so looks like red scamp wont be going
mike
mike
Well the only other option I can offer is that I send it down to you by carrier tomorrow or Tuesday, but that will cost about £7.00.
Give me a ring if you still have my number.
In my limited experience...
1) Take the top arm out,
2) Pop the knuckle joint out of the arm,
3) Feed the cone & hi-lo into the subframe,
4) Partially fit the top arm shaft thro (leaving the end plate off)
5) Swear several times & you can press the knuckle joint in,
6) Fit the shaft & end plate,
Job Done.
In my case add in some more steps...
1a) Remove engine mounts,
1b) Jack the engine up 1 1/2"
6a) Knacker the threads on the shaft & replace,
7) Lower the engine & refit the engine mounts.
Some additional steps have been removed due to too much swearing !!
2 front cones now replaced....almost a soft ride now !
Job Done.
its all ok job done bought metric cone compressor from mini- its just of m40 at Hockley heath on the way back froma job London yesterday.
now have 2 new top arm bearings and 2 new Avon cones from minisport , they are about 1/2 and inch taller than dunlop ones so just having top arms out didnt work! even with the hi lo adjusted to the smallest setting .It might still make it to stourport
thanks for your offers of help Chaz
and Neil's reply
and Neil's reply
» Tyres needed for Mk1
» Rubber fetish well sort of......
» Old age and poor memory -Help needed
» SU Help Needed
» A bit of help needed
» SU Help Needed
