WaveBox portable microwave
Just the thing for when you want your favourite snack while offroading - a portable microwave,
you will need a 20 amp rated socket not the normal fag lighter one - at around 140 pounds I don't
think it will replace the good old Calor gas cooker
Re: WaveBox portable microwave
At around 240 watts I don't think it will either.
Back in the 80's I was working on a different sort of portable microwave - output [classified] kW and it ran on aviation fuel. Well, it did if you thought of the aircraft and the radar as a complete system. Could have added a whole new dimension to ox roasts.
Bob, i dont know about roast ox , but we were always got told that it would roast our nuts
Now my trains have a track safety system (eurobalise) that will boil your brain if you walk under it before isolating it
A balise typically needs no power source. In response to radio frequency energy broadcast by an antenna mounted on the train, the balise transmits information to the train, such as: location of the balise; the geometry of the line, such as curves, gradients and speed limits; and the position of any signals. Balises are typically deployed in pairs so that the train can determine its direction of travel A->B from direction B->A. Balises often operate with equipment on the train to provide a system that enhances the safety of train operation.
So where's the power to boil your brain then
Martin & Nettie wrote:...So where's the power to boil your brain then
...to be fair..he's from Wolvo..so I suspect we'd be talking milliwatts.....
Hey i'm only a fitter,
i tried electronic stuff before and quickly decided that when things leak to earth i like to see the drips and puddles.
I was only relating like wot the brainier people and procedures were stating.
Anyway Martin how many hats have you worn/wear
Cheers John
Cheers John
Mk3rob wrote:Bob, i dont know about roast ox , but we were always got told that it would roast our nuts
The AEW radar had a link to the navigation unit which (amongst other things) stopped you turning on the transmitter too near the ground. It always worried me that the altitude was formatted as a signed value...
