Unfinished Mk2 on e-Bay
Here
Some interesting body mods - sloping front wings a la Mk1, linked wheel arches - but never registered, it would appear.
Re: Unfinished Mk2 on e-Bay
Are you sure its a mk2 - the kick in side rail over rear wheel is mk1 with a sub frame if I'm not mistaken
Is it a stretched Mk1
or
A Mk2 with a mk1 front end
either way it looks good
or
Unfinished Mk? on e-Bay
You may be right, Martin. I can't see the rear subframe, but as you say the back end is certainly set up for one. OTOH the twin roll bar is more normally found on Mk2s. The front end has been extensively modified (must weigh a ton!) and could have started off as either.
So, let's say a LWB Mk1 with Mk2 ideas retro-fitted.
» Un reg Un finished Mk3
» Mk2, unfinished rebuild
» Unfinished Jago £40!!!!!
» Unfinished project in Wales
» unfinished spartan treka kit car - fiesta mk 1 with full V5
