» Hello all first time scamper here
by Wrighty79 Yesterday at 9:07 pm
» Gov 6mth Ext on MoT's
by Mk3rob Wed Mar 25, 2020 3:55 pm
» Reluctantly for sale my 1977 mk2 Scamp
by Admin Sun Mar 08, 2020 8:58 pm
» Hello and looking to buy
by 77 SCAMP Tue Mar 03, 2020 9:49 pm
» Twinnie is back
by Mk3rob Sat Feb 29, 2020 12:02 pm
» (Almost) Free air Car
by Rum Tum Tugger Mon Feb 17, 2020 7:35 am
» Mk3 project darn sarf
by Mk3rob Sun Feb 16, 2020 6:40 pm
» 1970 GRANTURAYAK Mini based kit car ( SCAMP ) ?????????
by Rum Tum Tugger Sat Feb 01, 2020 8:56 am
» mk2 scamp tub on ebay
by Rum Tum Tugger Sat Feb 01, 2020 8:55 am
Removing Top Arm Needle Bearings
Removing Top Arm Needle Bearings Empty Removing Top Arm Needle Bearings
Post  OSR on Tue Sep 20, 2011 6:52 pm
Anyone have any suggestions on how to get them out? So far I've tried knocking out with a drift which has removed the inner case and the rollers but the outer bearing case seems very well attached to the arm and doesn't want to move. Is finding someone with a welding torch to leave on it until it glows red then try knocking through with a drift again the only option?
Removing Top Arm Needle Bearings Empty Hacksaw
Post  Mk3rob on Tue Sep 20, 2011 7:55 pm
Remove blade from tool, place through hole and re attach.
Saw ing through the outer race will allow the tension to release and should then be able to drift out.
Its worked for me on other bits in the past
Number of posts : 2462
Removing Top Arm Needle Bearings Empty Re: Removing Top Arm Needle Bearings
Post  OSR on Tue Sep 20, 2011 10:35 pm
Thanks for the tip Rob I'll give it a go.
Post  TRR Motorsport on Wed Sep 21, 2011 11:02 am
Or you could use a Sabre saw if you live near electricity. Laughing
