plugs and points
minirats
plugs and points
hi all i got a new set of both for my 1275 , thay were wrong it turn out it a 1960 to 70 rover 1300engine
minirats- Number of posts : 40
Job/hobbies : cars r/c boats
Re: plugs and points
The plugs will be fine but your engine will have a Lucas D25 dizzy instead of the later D45, hence you need different points.
Convert it to electronic and then you can forget about points
You won't be able to fix it by the roadside if it goes wrong though!!
mmmmmmmmm Lucas electronic ignition........Nice!
Therer's always the AA/RAC
points and plugs
was going to get electronic igntion some say good wat do you all think,
Electonic ignition gives you a more powerful spark,you also need the right coil with it,but,if it goes wrong there is very little you can do apart from replacing the whole unit,whereas if you have points and a condensor you can just whack another condensor in or another set of points in if it goes wrong.Also if it does go wrong you need a dedicated module tester,whereas with the trusty points you can just flick the points open to see if you have a spark.But,as Martin says,there is always the AA.
pounts and plugs
thanks for that i stick the new set in,and maybe it start better pickup new coil-plugs-leads-conds-will see if that dos the job
The electronic ignition will wear out coils quicker as the current is more of a on/off spike then you get with points. I've just bought a new coil for my Scamp and it cost £8 from M&M in Warrington. I had a very informative chat with one of the guys there as I'd gone in to get a replacement ignition module as I thought that was causing the lack of spark. Turns out that the module was a newish refurb one and probably ok. Apparently he rarely has problems with them, usually it turns out the coil has gone. Now the Scamp has a lovely spark but still doesn't start but that's another story
Last edited by OSR on Fri Feb 12, 2010 2:06 pm; edited 1 time in total (Reason for editing : thinking quicker then I can type :D)
We used to look after a fleet of metro vans and cars a few moons ago,we had the normal point type of problems like condensor failure etc.,but the ones with electronic ignition we had to buy an ignition module tester,it saved alot of guess work and you could test the coil along side the module.The coils gave very little problems(providing the correct one was fitted, i.e. there are ones for standard ignition,ones for balasted ignition and ones for electronic ignition) it was normally the good old Lucas module that we ended up replacing a few of,a simple job providing you can test it first.
pounts and plugs
put all new parts on .and she turn over about 5 turns then starts dont know wot to try next ?
Did you say "5 turns and it starts"..............wots your problem
How old is your petrol, as it does go off.
plugs and
it started on buton till last year. maybe it just old like it driver ,petrol is new
Is your ignition system ballasted (identifiable by a white/pink lead instead of plain white at the + end of the coil)? If so, possibly the ballast bypass isn't working. Measure the voltage between the + end and the chassis before, during and after starting - it should go up while starting.
For the uninitiated: in a ballasted ignition system you have something like a 6v coil instead of a 12v one, supplied via a resistor so it only gets 6v anyway. On starting, when the battery voltage drops under the load, an extra contact in the starter motor relay bypasses the resistor so the coil still gets enough volts to give a fat spark.
Its not PC to say "fat" you have to say "big boned" or "obese"
.........and Martin should know, he's been assesed by a professional
I am the right weight for someone who is 6 foot 2 - so its my height thats the problem
PS for those of you don't know me I am only 5 foot 6
Last edited by Martin & Nettie on Thu Feb 25, 2010 10:26 pm; edited 1 time in total
plug and points
that wot i like about the scamp club you can find a joke about plugs and points and still give good info , she start she runs and is fun c you all at next show
So don't forget,thin trim sparks,and connections on the coil that are sexless(not male or female).Oh and they are not sp--e connectors as this is not allowed either!!
Corpulent chance!Its not PC to say "fat" you have to say "big boned" or "obese"
So what was the problem in the end and how did you fix it,
or
was it the usual theory of if you strip it down enough times that it will fix itself when you put it back together again.
or
plugs and points
i change plugs + points+coil+leads+condeser+rota and to day i find choke not working right . i push it up a bit pushed button and she started . never mind all good for mot at end of march
Got there in the end thats the main thing
