» Completing the DVLC V55 Vehicle registration form
by Mk3rob Wed Jul 18, 2018 11:45 am
» Great looking Mk1
by Rum Tum Tugger Tue Jul 17, 2018 7:24 am
» Scamp badges on Ebay from Crawley
by Rum Tum Tugger Tue Jul 17, 2018 7:10 am
» UJ Flag Mk2
by Mk3rob Thu Jul 12, 2018 1:00 pm
» Ebay Scamp - Was Yellow the last time it was for sale
by Mk3rob Tue Jul 10, 2018 3:18 pm
» Mk2 on Ebay - High start price
by Mk3rob Sun Jul 08, 2018 2:21 pm
» RTV Mandry / Mclean
by Mk3rob Sun Jul 08, 2018 2:20 pm
» Fuel tanks
by Mk3rob Sun Jul 08, 2018 11:45 am
» Scouse Scamp mk2 G Reg
by Rum Tum Tugger Wed Jul 04, 2018 8:55 am
MOT pass or fail?
MOT pass or fail?
Post  Jono on Tue Nov 10, 2009 1:37 pm
First off, Ian, I'm not "having a pop at you", you sold me the motor in good faith and I don't doubt that. You might want to have a word with your MOT station though.
..so the story goes... Ian (t'other one) should be coming down to purchase said motor this weekend and I remember that I've still got to re-fit the alloys to the front having taken off the over-sized Knobblies ( Yes, I know)... at the same time, I think to myself, I'll just swap the rears to the front as they have slightly more tread and check out the rear shock mount 'cause it's just touching the inside of the tyre when off-roading....this is what I found. Bear in mind Ian (The first one) had, obligingly, put 12 months test on her before he sold her to me and she's done maybe twenty odd miles since..all at Stourport!
Backplate rotten through and seriously buckled and not one..but two spacers fitted.......MOT pass?
Re: MOT pass or fail?
Post  ZED on Tue Nov 10, 2009 2:11 pm
It'd fail at the garage that we go to.......
Sitting on the fence,
E.
Post  TRR Motorsport on Tue Nov 10, 2009 7:36 pm
Umm Brail MOTs, Nice!
Post  minibuger on Tue Nov 10, 2009 8:23 pm
The spacer's would be hard to see with a wheel on ,and as for the back plate thay are made in two parts and spot welded together if its only the outer rim (grit gaurd) that as rotted off it will not affect the brake in any way and would be down to the tester to pass or fail as its none stuctual .I would have failed it but some testers and its down to the tester , may have done a advisory notice on it (VT32) .You can see if one was given on www.vosa.gov.uk
minibuger
Number of posts : 90
Job/hobbies : CARS, CARS AND MORE CARS. GREASE MONKEY
Registration date : 2009-05-06
View user profile http://sites.google.com/site/stimsonminibug/
Post  ZED on Wed Nov 11, 2009 7:06 am
minibuger wrote:You can see if one was given on www.vosa.gov.uk
Yes, it's a good site that is.
E.
Post  Jono on Wed Nov 11, 2009 7:21 am
minibuger wrote:The spacer's would be hard to see with a wheel on ,and as for the back plate thay are made in two parts and spot welded together if its only the outer rim (grit gaurd) that as rotted off it will not affect the brake in any way and would be down to the tester to pass or fail as its none stuctual .I would have failed it but some testers and its down to the tester , may have done a advisory notice on it (VT32) .You can see if one was given on [url=http://www.vosa.gov.uk
www.vosa.gov.uk[/quote[/url]]
Good point about the spacers.
The backplate is corroded. Not just the outer rim. I have the MOT in front of me. No advisory issued.
Post  Rum Tum Tugger on Wed Nov 11, 2009 7:33 am
Any possibility the backplate at least looked OK before Stourport?
Number of posts : 940
Post  iank on Wed Nov 11, 2009 7:41 am
Frankly I'm really glad Jono spotted it and didn't just bolt the wheel on and wave goodbye. affraid Top bloke.
Driving 250miles could have been exciting if it had let go, though the amount of braking done by the rear end of such a light car won't be much jamming on would have been another matter.
Oh well, still going to get my hands on it one way or another Smile though it's going to get another MOT before it goes on the road just in case there's anything else the testers guide dog missed.
iank
Number of posts : 10
Job/hobbies : Embedded Software Engineer / Kitcars, Electronics, Programming etc etc
Registration date : 2009-10-28
Post  TRR Motorsport on Wed Nov 11, 2009 12:46 pm
"Woof woof, Woof, Woof-woof, Woof!"
The MOT Dog say's that the ramp was too high and he couldn't see properly but if you take the car back he'll cast his paws over it for a nice biscuit!
Rear wheel spacers
Post  Mk3rob on Wed Nov 11, 2009 4:23 pm
I read a while ago that anymore than about 10mm knackers your wheel bearings.
Number of posts : 2350
Post  minibuger on Wed Nov 11, 2009 4:45 pm
Mk3rob wrote:I read a while ago that anymore than about 10mm knackers your wheel bearings.
All later minis from 84 on i think where all fitted with 1" spaced rear drums so i would think you should get away with a 1" spacer on a standard wheel offset ,but the bigger the offset the more strain on the bearing.
I read that you are not to use alloy spacers on alloy wheels thats why alloy wheels have steel inserts where the studs go .So if this is true two alloy spacers on the same wheel can't be good..
minibuger
Post  Jono on Wed Nov 11, 2009 5:31 pm
"Spaced" drums were used from '84 because the switch to discs effectively gave a wider track, so a wheel with less offset/more inset was used to maintain overall vehicle track. Therefore "effective" leverage on the bearings stays the same.....I think.....
Two spacers just doesn't "feel right" from an engineering standpoint, though I suppose there is no real issue assuming they're good quality/fit.
I can't see the problem with Alloy spacers if they're solid and the right grade etc...no-one has an issue with the Minifins with the built in spacer....or do they?
Post  minibuger on Wed Nov 11, 2009 9:41 pm
Dont minifins still have steel inserts in the stud holes ?? That why the cheaper copys are s--t think it was in one of the mini mags.Also the track on the front of a mini as always been wider than the back as wider drums on the rear was added to the 1st cooper s mk1 and 1275gt's fitted with the disc's to bring them in line ..
Not me but been on google ....
Track width was 47.5 inches / 3 feet 11 and 1/2 inches* (1207mm) at the front, and 45.7 inches / 3 feet 9 inches and 3/4s (1162mm) at the rear.
*Might be 3 feet 11 and 3/4 inches wide at front, and 3 feet 10 and 1/2 inches at the rear, depending on version.
minibuger
Post  Jono on Thu Nov 12, 2009 8:10 am
minibuger wrote:Dont minifins still have steel inserts in the stud holes ?? That why the cheaper copys are s--t think it was in one of the mini mags.Also the track on the front of a mini as always been wider than the back as wider drums on the rear was added to the 1st cooper s mk1 and 1275gt's fitted with the disc's to bring them in line ..
I think we're saying the same thing aren't we? The geometry of any disc-braked Mini meant, using drum braked rims, the track would be way outside the bodywork. So to bring the track back, the wheels fitted had more inset. So when these new (greater inset) wheels were fitted to the rear, they would foul on the inside. Therefore spaced drums were used.
