» Completing the DVLC V55 Vehicle registration form
by Mk3rob Wed Jul 18, 2018 11:45 am
» Great looking Mk1
by Rum Tum Tugger Tue Jul 17, 2018 7:24 am
» Scamp badges on Ebay from Crawley
by Rum Tum Tugger Tue Jul 17, 2018 7:10 am
» UJ Flag Mk2
by Mk3rob Thu Jul 12, 2018 1:00 pm
» Ebay Scamp - Was Yellow the last time it was for sale
by Mk3rob Tue Jul 10, 2018 3:18 pm
» Mk2 on Ebay - High start price
by Mk3rob Sun Jul 08, 2018 2:21 pm
» RTV Mandry / Mclean
by Mk3rob Sun Jul 08, 2018 2:20 pm
» Fuel tanks
by Mk3rob Sun Jul 08, 2018 11:45 am
» Scouse Scamp mk2 G Reg
by Rum Tum Tugger Wed Jul 04, 2018 8:55 am
damaged crankshaft seal
Post  lin and tony on Sun Mar 01, 2009 9:05 pm
Does anyone know if there is a way of taking the bell housing off, to get to the crank seal, without taking the engine out - again!
Having got the engine in, everything up and working, I tipped the car onto its side and fitted the exhaust, then started the engine to see what it sounded like. Suddenly there was oil pouring out of the bendix slot. Apparently I had damaged the seal when fitting it weeping weeping Not a happy bunny!
Number of posts : 593
Re: damaged crankshaft seal
Post  Rum Tum Tugger on Mon Mar 02, 2009 8:01 am
I've changed clutches before now with the engine in situ, so the seal ought to be possible too. Especially on a Mk2 where you have a bit more clearance between the engine and body.
Essentially you have to tilt the engine by jacking it up under the gearbox at the clutch end, until you can get to all the clutch cover bolts (offset ring spanners are handy at this point). It's necessary to remove or disconnect the radiator (top bits at least), carb, exhaust, gearchange, engine mountings and steady bar.
It's one of those jobs where you run out of swear words and get to invent some new ones. If you've only just replaced the engine, with all the nuts & bolts clean & oiled, and you have a well placed hoist, it's almost as easy to whip it out again.
Have fun!!!
Number of posts : 940
Post  TRR Motorsport on Mon Mar 02, 2009 12:48 pm
You didn't slide the seal over the drop gear without a sheath over it did you? Rolling Eyes
It's an easy job to do & you don't have to remove the motor. Drain the oil, support the gearbox with a jack, take the bell housing & flywheel off (as if your doing the clutch) and then remove the dropgear cover plate. remove the duff seal, fit new one and refit, but this time have a roll of plastic over the gear to protect the seal as it passes over the gear. I cut a strip of plastic from an old tub of engine oil. It's flexible enough but not too thick. Then refit the clutch etc...
You should be able to do it easily in about 1 - 1.5 hours. Or 15 minutes during a service break Very Happy
Post  Martin & Nettie on Mon Mar 02, 2009 4:21 pm
Isn't sheath a posh word for a condom?
Post  Mk3rob on Mon Mar 02, 2009 10:58 pm
How would James know.............he obviously doesnt use them Twisted Evil
Number of posts : 2350
Post  Martin & Nettie on Tue Mar 03, 2009 11:22 am
He uses a strip of plastic cut from an old tub of engine oil - what sort of oil comes in a tub.................................................margarine?
Post  lin and tony on Tue Mar 03, 2009 6:22 pm
Thank you so much for the enlightening discussion!!!!
All done and dusted. Didn't completely remove the engine again. I had pushed the seal in too far. I thought there would be a shoulder on the casing - now I know there isn't! And it did only take the 15 mins - ish. Again, thanks to Jono's hoist!
The only problem was - when I got it all back together, I found a horseshoe clip still sitting in my tool box - Doh!
All sorted - Next problem..... Question
HOPE to see you all at Easter Exclamation Exclamation Exclamation
