chasis number
johnonthetyne
chasis number
while filling out application form for club ,where will i find the chasis number??
johnonthetyne- Number of posts : 56
Job/hobbies : nurse
Registration date : 2009-02-01
Re: chasis number
Ok I see, havnt got v5 yet, am going to call dvla int morning
Job/hobbies : nurse
Re: chasis number
The Mk3's have a welded number on the inside of the front of the engine bay.
It consists of the Kit no. and the date of manufacture.
This is the number on my logbook and the one that they use for the MOT.
Re: chasis number
Jst had a quick look, couldn't see anything at all, seems like it's all ally apart from main frame
Job/hobbies : nurse
Re: chasis number
Mk2s don't have a number welded on from them the 'factory'. Your only hope is the dvla............johnonthetyne wrote:Jst had a quick look, couldn't see anything at all, seems like it's all ally apart from main frame
Re: chasis number
Kit purchasers were given the chassis number on the receipt, but it was up to them how they applied it. The usual method was to beg/borrow/steal a set of number punches, make one from a bit of scrap ali and affix this with pop rivets. At this time in history there was no standard place for it, so it could be anywhere readily visible. Given a bit of wet and enough years, the ali pop rivets eventually failed (see Galvanic corrosion) so the only evidence you might have now is a couple of spare rivet holes...
I believe some people took the number punches to the actual chassis itself, but in this case again, corrosion may well have obliterated the result by now.
The only satisfactory long term solution is the one adopted by Mr. MacLean, that of writing the number on the frame in weld.
Re: chasis number
sucess, there is an insignificant tiny peice of ally pop riveted to bulkhead, when i scraped of the crud sure enough theres a number stamped on it , thanx.
johnb.
johnb.
Job/hobbies : nurse
Re: chasis number
Don't keep us in suspenders what is the number
Re: chasis number
oh i see, ill have a look in a bit,
Job/hobbies : nurse
Re: chasis number
its***** , does this mean anything to anyone?
Job/hobbies : nurse
Re: chasis number
That sounds about right.
Re: chasis number
Yes, it's 84 chassis' before mine.johnonthetyne wrote:its 20471 , does this mean anything to anyone?
Re: chasis number
Thanks for the info, I've started dismantling it, few rotton bits but nothing that would compare to a mini,av got mig welder so should be a doddle.
Job/hobbies : nurse
Re: chasis number
now ive got reg number and chasis number ive downloaded form v62 and i should be able to get new v5 with £25
Job/hobbies : nurse
» Now thats what you call a strong chasis
» Scamp Chassis Number
» Chassis number
» location of chassis number plate
» My scamp help please
» Chassis number
