» Expensive Scamp - Again
by Rum Tum Tugger Today at 8:13 am
» Mk1 Scamp on Ebay
by Mk3rob Yesterday at 7:25 pm
» mini based kit car adverts
by Mk3rob Mon Dec 03, 2018 8:41 pm
» Renault Scamp
by Mk3rob Mon Dec 03, 2018 8:38 pm
» 1972 Scamp on Ebay
by Lemon-scamp-i Fri Nov 23, 2018 7:41 pm
» Maximum Mini Books by Jerone Booij
by Lemon-scamp-i Fri Nov 23, 2018 4:28 pm
» Mk 1/2 on Ebay
by Mk3rob Thu Nov 22, 2018 6:52 pm
» Donnington Park Car Museum shuts
by Mk3rob Sat Nov 03, 2018 9:55 pm
» For sale 1971 Mini Scamp kit car
by amrobinson Wed Oct 24, 2018 10:16 am
Rob's refurb
Rob's refurb
Post  Mk3rob on Wed Jan 28, 2009 8:33 pm
Well now that my carport/garage has got a proper roof and i have filled in the other large holes its about time i pulled my finger out and started the refurb of my front suspension and driveshafts. I have superglued the cv gaiters for the last two MOTs and i dont think that the "man" will pass it again.
Like Tony I also have Hi/Lo's to fit, plus cv joints, wheel bearings and various bushes.
While i'm at it a bit of a paint job around the area.
The carport/garage area is only wide enough to do one side at a time. or is it practice on one side and hopefully get the second right.
I have also got and half fitted a blue pvc trailer cover which is going under my canvas top (which sags and leaks), well for this season anyway!
Oh well back to work tomorrow, at least on Saturday i can use the white spirit (or what evers in it) bath to clean my bits. There's nothing like a good scrub with a wire brush affraid
More later Rob
Number of posts : 2376
Re: Rob's refurb
Post  Rum Tum Tugger on Thu Jan 29, 2009 6:28 am
On the other hand, sometimes the first side goes like a dream, and you get that feeling of "what was the problem, I can do it after all".
Until the second side brings you down to earth... irked
Number of posts : 948
Re: Rob's refurb
Post  Mk3rob on Sun Feb 08, 2009 8:31 pm
Well after finally getting all the bits out and dismantled, the haynes book lied again "simply remove the cone from the doughnut" with the use of the works big engineers vice and club hammer, well i wasnt using the cone again anyway.
All the bits had a good wire brushing, a dust over with black and then a brush coat of dark blue. well i still had a bit left in the can.
Wednessday was fine so off i went from the top of Wolves around to the M5 J2 to go to Mini Spares. 30 mins later and B/card heavier by 200 ( no wife/partner/missus to placate) i went home again.
Fri on hol before Pub do on Sat it was time to start the rebuild. The old hub nut had come off without the gaiter and splined UJ drive, the new one with the gaiter fitted is a bigger diameter and will not fit through the subframe driveshaft oval hole. Eventually had to disconnect the bottom mount (passenger side) to get it in. Oh and yes i did drain the oil first!
The doughnut, HiLo went in and the top suspension arm with new knuckle joint.
All this work just because the cv gaiters were split (I had super glued them for the previous 2 MOTs), but when you break it all down to do the drive shafts, you are just as well to keep going as i dont intend doing it again.
Afternoons this comming week, can Rob get off his back to do a couple of hours in the morning before going to work...............watch this space,
Fitting hi/los
Post  lin and tony on Sat Feb 21, 2009 9:22 am
Well Rob, it sounds like your hi/lo fitting ent better than ours!
Jono kindly brought us the tool to borrow - didnt fit so he brought the bit with the other thread. - Still no joy - looked to see, on here, how you had done yours - Tony was a little worried about bringing in the heavy mob (lump hammer etc) So at this precise moment - mechanic friend at the ready - Colin on the phone - wonder what will happen next?!!!!
Watch this space! What a Face
Re: Rob's refurb
Post  lin and tony on Sat Feb 21, 2009 9:35 am
Well - lump hammer and heavy chisel did it! cheers Should have listened to you in the first place Exclamation Fortunately, Tony THINKS he has all the spare parts needed to replace those broken - but he hasn't checked yet to find out What a Face Hope mini spares are open on a Sat pm!
Re: Rob's refurb
Post  Mk3rob on Sat Feb 21, 2009 1:42 pm
Well i have had the last 4 days off 1X hol 3x rest day before starting 5 nights tonight.
Well the passenge side is all back together after splashing some paint around the subframe and wheel arches.
The new /refurbed bits went back in (its so much enjoyable working with clean parts) and after a bit of chicken n egg it was back onto its wheels and out of the garage to swop sides.
On Thurs after my monthly trip to the chiropractor (shoulder) and some lunch it was time to get at the other side.
Due to the end of my drive sloping down to the sloping road, the easiest way was to get the neighbour to shift her car of the ajoining drive and then do a 7 point turn to get it back into the garage.
Back in and the sun streaming in and warming me up the fun all started again.
I knew from last time that the top ball joint was seized on, so the lower one i managed to crack and the top one i was able to undo the locking cap and pull it all out of the hub. The lower arm seized on the wiggly sub frame pin but with some fiddling that also came out.
Friday pm was a case of getting my drill and angle grinder out to remove the tapered stubs of the ball joints from the arms.
*******Note for Tony*********
To get the cones off the doughnuts (thats if you dont want to keep the cones) i clamped the doughnuts in the workbench and hacksawed down between the rubber and the cone. when 3/4 around a few light taps with our mate the club hammer and the rusted cone ring came out of the doughnut. Well it worked for me and saved a lot of messing around.
Well i've had my lunch mand now its time to do some more painting of the wheel arches.
Tonight i will be putting my bits affraid in the cleaning boasch and giving them a good scrub.
Then tomorrow start painting them up.
Amazing when i didnt have a roof on my garage it was raining, now i have its nice and sunny and warm by comparrison.
Keep at it Tony, you know it makes sense!!
Pics test
Post  Mk3rob on Sat Mar 07, 2009 3:46 pm
Pics
Post  Mk3rob on Sat Mar 07, 2009 3:52 pm
Well that hopefully will keep the Mot man happy
Well that one loaded.
Although when i tried to load more images onto the samepage it didnt want to play.
There again i was always better with a hammer and chisel
Re: Rob's refurb
Post  Mk3rob on Sat Mar 07, 2009 3:54 pm
Re: Rob's refurb
Post  Regsmonster on Sat Mar 07, 2009 10:00 pm
Looking good Rob! Very Happy
Re: Rob's refurb
Post  Martin & Nettie on Sun Mar 08, 2009 5:23 am
Bob its a Scamp your doing not a Virgin train? all that lovely paintwork, someone's going give James a run for his money - perhaps a new trophy should be awarded for the best presented suspension and drive train (painted driveshafts that going a bit far isn't it) Question
Re: Rob's refurb
Post  Rum Tum Tugger on Sun Mar 08, 2009 1:09 pm
When I built mine, I got a gallon of silver Hammerite and painted just about everything under the bonnet. Now, 35 years later, I can soon tell which bits have never had to be replaced.
And I've still got about half a pint of rather thick paint left in the tin...
Re: Rob's refurb
Post  Mk3rob on Sun Mar 08, 2009 2:41 pm
What your trying to say is that it wont help me get up that damn hill any better Mad
I've also stolen an idea from James for wheel arches Twisted Evil
Tuning next month Very Happy
Re: Rob's refurb
Post  nhazelwood on Sun Mar 08, 2009 8:16 pm
Looks like Blue Is the hot accessorising colour this summer....
I've gone pearlescent blue... should look even better with a nice coating of red clay at Stourport !
Re: Rob's refurb
Post  TRR Motorsport on Mon Mar 09, 2009 12:11 pm
OMG! Shocked
That IS blue! Looks great though. Cool
There is some effort going into the winter refurbs this year isn't there? I think 2009 is going to ba a golden year for Scamps for sure. Wink
Re: Rob's refurb
Post  nhazelwood on Mon Mar 09, 2009 12:42 pm
Looks even more sparkly in the flesh... i know it takes ages to get it off your nails. i dont use it to do my nails with....just hold a part while you spray it & voila several blue fingers.
I thought blue would go well with the yellow body colour. Glad i chose not to use my daughters favourite colours...Pink Body & purple accessories Shocked
Refurb & MOT
Post  Mk3rob on Tue Apr 14, 2009 12:19 pm
Well the running gear refurb is finally finished cheers
and it has now got a new MOT on it, well 2nd time around Embarassed
After stripping down the front suspension and driveshafts and spending 200 at Mini Spares (well i dont intend to do it all again), why didnt i spend 7.50 on a track rod end..Doh Rolling Eyes (thats all it failed on).
At the same time I fitted Hi/Lo's, now all i have to do is get used to how far i need to adjust them to get the difference between road running and what wil be needed for Stourport.
I also have picked up 5 alloys with 4 good tyres on them (2 need reseating or tubes) from E-bay for 52.50.These will get used on the road and the steels on the rear i can now put my knobblies on and swop front too back.
Have just done a road test on my favorite test track.......M54 J2-3 and back along the A5 and down the 449 into Wolves.
On the 27th i have got it booked onto a rolling road near Dudley to try and get some lower revs accelleration out of the donkey (or is that me Question an interface problem).
After that hopefully, it will be ready for the run down to Newquay and the Riviera Run on the May Bank Holiday. Very Happy
Watch this space
Rolling Road
Post  Mk3rob on Tue Apr 28, 2009 7:03 pm
Well the last it for this year was done this afternoon.........rolling road set up! Very Happy
www.aldonauto.co.uk Brierly Hill, sth of Wolves - nth of Stourbridge
Well after they changed the vacuum part of the dizzy, cause there wasnt much advance / retard happening and changed the carb needle for a better one is was time to thrash it. 5000 rpm affraid the poor little sods only done 4000 when i've driven it
My engine is a 998 A+ and the end result was 51bhp at 4999 rpm at the fly wheel clap woohoo
Yes James and Reg, i know you wouldnt get out of bed for that rpm, but "its only a puppy" not a gert big rottie affraid .
So hopefully i might manage to get up that bloody hill this year banghead at the picnic
Now hopefully, i am all ready for the Newquay Riviera Run this weekend. Any one else going?
Re: Rob's refurb
Post  Jono on Wed Apr 29, 2009 3:40 pm
51 Gee-gees..is a pretty healthy 998. Very Happy
Re: Rob's refurb
Post  TRR Motorsport on Thu Apr 30, 2009 9:33 am
I'm impressed with the BHP Rob and well done for using Aldon. Those lads know A-series backwards and how to set a car up on the rollers properly.
Pea originally had a low compression van engine 998cc = 37BHP! And 12" wheels. Still if you can drive a small underpowered car quickly then driving a bigger overpowered car (Sunbeam) can be done really quickly!!!
Standard 998cc minis were 44BHP? and 998cc A+ Metros were a little more. but 51 BHP from a engine that has been around a while is pretty respectable. Laughing
Re: Rob's refurb
Post  Mk3rob on Thu May 07, 2009 9:29 pm
Lesson 42
Once you have done a run (20 miles to RR and back) i thought all was ok........not.
I thought the dicky battery just needed a good run to charge it up - !00 miles down to Swindon before Rivera Run in the dark and it looked ok .........next day on the way to Newquay whats that sulphorous smell.......well the alternator was over charging so we disconnected it and continued on the battery.
Mon am new battery (oh we have just run out of mini batts..doh) 70, tested the charging and the alt was not producing any thing..repaired a wire and still the same. Oh well down to Plymouth to see my sistersand in pm stripped down the alt (less than 2 years old) brushes ok put it back together, still knacked.
Tues am bro in law took me into plymouth to a back street type shop on main A38, he just does starters and alt, brill shop. Had a brand new alt, changed the pulley gap and thankyou very much for the 50.
Tues evening travelled up to Wolves, 200 miles in 3 1/2hrs. all ok or so i thought. The front tyres were bald affraid for the outer 1/3rd (mutter mutter) .Part worn tyres on my alloys with 32mm spacers and stud extensions.
On way to work wed pm booked scamp in to get tracking done thurs pm. Thurs am thought i would put original steels back on front just to make sure it wasnt the alloys.
Wobble wobble the wheel bearing was loose!!!!!!!!!! Well i had really packed the bearings well with grease and gave the hub nut a good bollockin up, but sods law you can only go to the nearest splitpin hole.
Oh well roll it back in to the garage and go to work. I now have to get the hacksaw out to break into my sheds because i lost the keys when i cleared up after my refurb.
That was 500 miles and on the motorway ave 70 and got 28 miles to the gall
Do i win the prize for the best sob Crying or Very sad story of the year.
Re: Rob's refurb
Post  lin and tony on Thu May 07, 2009 11:16 pm
Hard luck Rob - but I think you will have to do better than that! The year - or Scamping season is yet young - and several of us have had to remove engines and start again (2 diffs in the Peak district to my knowledge! pale ). I am sure more interesting poblems will also come to light over the following months.
They're not called Scamps for nothing!
Hope all is well with your Scamp again soon.
Re: Rob's refurb
Post  TRR Motorsport on Fri May 08, 2009 8:32 am
Oh Dear Rob,
It sounds like your 2009 is starting very much like everyone elses, two steps forward, three steps back. Rolling Eyes
On the upside though I think your Scamp has turned into a Lotus, you lucky sod!
Lots
Of
Trouble
Usually
Serious
Oh, and Exiges are exempt from the above on the count of their nice reliable Toyota engines Wink
Re: Rob's refurb
Post  Regsmonster on Fri May 08, 2009 8:48 am
TRR Motorsport wrote:Oh Dear Rob,
And Excels and Turbo Esprits.
I'm glad I don't own a TD5...................... tongue
Re: Rob's refurb
Post  TRR Motorsport on Fri May 08, 2009 12:14 pm
I heard that Lotus will be using the TD5 oil burner in their new track day special. It's going to be called the 122R ! pirat
Re: Rob's refurb
