» Woo Woo Tywyn
by Mk3rob Today at 3:45 pm
» 2018 Events
by Mk3rob Tue Feb 20, 2018 3:08 pm
» Mk2 on Ebay
by Rum Tum Tugger Tue Feb 20, 2018 8:26 am
» Mk2 Scamp down Brissole way
by Mk3rob Tue Jan 30, 2018 6:23 pm
» Mk2 for sale in N Ireland
by Mk3rob Tue Jan 30, 2018 6:20 pm
» 1380 engine less the scamp
by Mk3rob Fri Jan 26, 2018 2:50 pm
» Cheap (NOT) project on E bay
by Mk3rob Mon Jan 22, 2018 4:37 pm
» And you think you got problems?
by Rum Tum Tugger Thu Jan 18, 2018 5:03 pm
» One for Bob
by wezgit daan saaf Fri Jan 12, 2018 11:53 pm
Mk2 mini scamp fuel tank wanted
Post  Bobby64 on Sat Jun 20, 2015 7:55 pm
Looking for a mk2 fuel tank for a mini scamp if anyone has one or knows where I can get one please can you let me know cheers.
Bobby64
Number of posts : 2
Job/hobbies : Car restoration
Registration date : 2015-06-18
Re: Mk2 mini scamp fuel tank wanted
Post  nhazelwood on Sun Jun 21, 2015 10:46 am
Morning,
Got one sat on my garden bench at the moment......
Measures 515 mm (20 1/4") wide, 160 mm (6 1/4") deep & 285 mm (11 1/4") high.
Fitted with a mini van fuel sender on the right hand side....also fitted with an astra electric fuel pump in the left hand side...finished is a slightly foxed texture black finish, (will strip off easy)
The original outlet pipe is on the left hand side and still fully usable (As Walle has a fuel injected astra engine, the original output was used as the return line & the outlet is from the astra pump....) Holds fine when pressurised, just needs a new gasket for the fuel sender.
The astra pump can be removed from the side & a blanking plate made & fitted if original use is needed....key & astra plug for wiring are also with it.
Now surplus to requirements, as i'm nearly finished making a bigger stronger & much heavier tank Embarassed
Post  Bobby64 on Sun Jun 21, 2015 8:44 pm
Seen the fuel tank where are you and how much you looking for it cheers.
Bobby64
Number of posts : 2
