Bulging Chassis Tubes.
Re: Bulging Chassis Tubes.
I think it really depends on how load bearing they are.
I had a couple that were starting to go that way.
Mind you a 3lb club hammer and a coat of paint worked wonders.
Mine was not on a restoration at the time mind you, oh and I cant weld
bulgies
I had one on the very rear left hand upright of my mk2 obviously been full of water and frozen (it lived outside in the middle of a go kart track for several years) I ended up slitting the corner with a 1mm disk flattening the corresponding faces and grinding any excess due to stretching and then welded the corner - tidied up, you wouldn't know anything had happened and is still as strong as its fully welded.
» Chassis Tubes.
» mk2 chassis on ebay- no paperwork
» Mk2 (?) chassis on E-bay
» SJ 413 Chassis
» SJ 413 Chassis
