» A Frame Fitted, anyone?
by Dirtyscamp Yesterday at 11:15 pm
» Shorty Scamp for sale (again)
by Mk3rob Thu Jan 17, 2019 1:25 pm
» Early 2019 sale
by Mk3rob Thu Jan 17, 2019 1:23 pm
» Scamp Wanted!!
by Scamper Tue Dec 18, 2018 11:40 pm
» Expensive Scamp - Again
by Rum Tum Tugger Tue Dec 11, 2018 8:13 am
» Mk1 Scamp on Ebay
by Mk3rob Mon Dec 10, 2018 7:25 pm
» mini based kit car adverts
by Mk3rob Mon Dec 03, 2018 8:41 pm
» Renault Scamp
by Mk3rob Mon Dec 03, 2018 8:38 pm
» 1972 Scamp on Ebay
by Lemon-scamp-i Fri Nov 23, 2018 7:41 pm
Alloy Panels.
Alloy Panels.
Post  Steve G on Fri Mar 14, 2014 10:08 pm
Re: Alloy Panels.
Post  Rum Tum Tugger on Sat Mar 15, 2014 8:57 am
As far as most builders are concerned, it's because that's how the panels were supplied!  As to why they were designed that way, you'll have to ask Robert Mandry, John Medhurst or Andy MacLean.  I'd guess though that it was simply because it looks neater.
Advantages - appearance; no exposed edges to catch on passing trees, bushes and other off-roading hazards; can be fitted either flush or recessed.
Drawbacks - awkward to fit, to do it properly you need an angle drill; making a replacement needs professional metalworking gear.
Number of posts : 948
Re: Alloy Panels.
Post  Steve G on Sat Mar 15, 2014 2:29 pm
Re: Alloy Panels.
Post  nhazelwood on Sun Mar 16, 2014 12:39 am
Hi Steve,
If you fancy a nice flush look, you could always make the panels in steel & then weld them flush with the outside of the box section. A quick grind off & some filler / primer & topcoat later a nice smooth look....
Be warned, this is not as quick or easy as it sounds......once its done it look's cracking, while your doing it you'll crack up.
A very rough pick of the cracking up stage.....
If you want a pick of the cracking finished look, i'll take a pick later today...when its light...
Re: Alloy Panels.
