Mk 2 Rebuild.
Page 3 of 3 Previous  1, 2, 3
Mk 2 Rebuild. - Page 3 Empty Re: Mk 2 Rebuild.
Post  Mk3rob on Mon Jun 30, 2014 10:24 pm
Wot, unlike the gash welding of a couple of years ago Twisted Evil
Post  Steve G on Mon Jun 30, 2014 10:49 pm
I cleaned this up a bit but realised the it was actually pushed backwards. I think at some point in it's past the subframe towers have broken and the subframe mounts have all moved.
Post  Steve G on Thu Jul 03, 2014 12:42 am
I had the nice shiny steel tube delivered so it was time to get started.
Post  Steve G on Mon Jul 07, 2014 4:03 pm
Holding the bits straight ready for welding.
Post  Regsmonster on Tue Jul 08, 2014 1:49 pm
Loving all this precision cutting and welding!
You do know that Mk2's are half an inch longer on one side than the other don't you?  :lol:
Post  Steve G on Tue Jul 08, 2014 5:14 pm
That must be a good one !
I am beginning to realise they aren't perfect. The original crssmsmber was pushed back quite a bit so hopfully that will be fixed when this is attached.
Post  Steve G on Thu Jul 17, 2014 2:24 pm
I cut some tube to make the new subframe mountings and bolted it onto the subframe. It's a start on getting the subframe re-attached to the car again.
Mk 2 Rebuild. - Page 3 Empty Ummmmmmmmmmmmmmmmmm
Post  Mk3rob on Thu Jul 17, 2014 6:01 pm
I reckon that you are going to have the cross member fouling the top of the wheel when you have the engine. Shocked
Unless, they are 13" and you intend to put 12" on it.
Post  Steve G on Thu Jul 17, 2014 6:44 pm
The front is help up with blocks of wood where the bump stops should be at the moment. Your right the tyre will rub but I will be cutting the lower box section back to give clearance once it's all welded in. I thought it would be easier to keep it all straight doing it like this. Hopefully I have worked it all out right or I will have to fit 10" wheels on it !
Post  Steve G on Thu Jul 17, 2014 11:20 pm
Post  Mk3rob on Fri Jul 18, 2014 5:53 am
Which proves the point
Nothing is standard on a Scamp
You make it up as you go along Very Happy
Post  Steve G on Fri Jul 18, 2014 9:24 am
Steering rack and subframe mounts. Pretty much the same as normal just higher up on the chassis to match the repositioned subframe.
Where I am with the new pedal box mounting. It needs quite a bit more work yet but I think it will work OK.
Post  Steve G on Wed Jul 30, 2014 12:00 pm
A few more pictures of what I have been doing. The subframe mount/crossmsmber will be cut away in the center for carb clearance.
Post  Steve G on Mon Aug 18, 2014 5:56 pm
I got hold of these seats. I'm not 100% sure I will use them yet but they are so much more comfortable than Mini ones. Put a bit of paint on the new tubes as well.
I've offset the central tubes to allow clearance for the carburettor /air filter. It will also give a bit more room if I decide to fit a weber or some sort of injection system in the future.
This is the engine that will be going in it. It's a 1380 with a balanced bottom end and a 286 cam. Not sure about the output but with it geared to do about 100 mph at 7000 rpm it went quite well.
Post  Steve G on Sat Sep 13, 2014 9:17 pm
I had a bit of a look to see what it will be like when finished, gives me a bit of practice on photoshop ! I have angled the screen pillars back a bit more and covered the bulkhead tube with a 1 piece side panel as it looks a bit odd being a different angle.
Post  Steve G on Fri Sep 19, 2014 11:30 pm
I needed to finish welding the various bits I had fitted at the front and the easiest way to do that was to turn it over. I had to strip the subframe, pedals, steering column etc out to do this and once it was welded I cleaned it up and gave it a quick coat of primer. You can also see I have joined the steering rack mount area to the bulkhead. I'm planning on running some square tube around the toeboard area but I don't know where that will go until I sit the proper suspension and wheels so I can work out various clearances.
Post  simonice on Wed Oct 22, 2014 4:46 pm
Great project thread. Def pointed out a few things I need to watch out for on my rebuild Smile
How much further have you got with this?
simonice
Number of posts : 18
Job/hobbies : Allsorts!
Registration date : 2014-10-22
Post  Steve G on Mon Mar 16, 2015 4:48 pm
Hopefully as soon as I can put some sort of shed up I can get on with it again I would have done that a bit sooner if I hadn't finally, after about 7 years, put up our greehouse !
Post  Mk3rob on Tue Mar 17, 2015 7:23 pm
Exactly the same place that my Mk3 has the chassis number welded on it.
Post  Steve G on Tue Mar 17, 2015 8:13 pm
I haven't seen under the bonnet of a MK3 but it seems a pretty logical place to put it. The only problem is that it's a part that might be replaced in the event of an accident.
Late Andrew MacLean built Mk2's had their numbers welded onto the drivers side subframe mount brace bar I understand so there is no chance of them getting lost.
Post  Mk3rob on Tue Mar 17, 2015 8:15 pm
Repair / reweld
Post  Steve G on Tue Mar 17, 2015 8:22 pm
Mk3rob wrote:Repair / reweld
My welding would have to be a whole lot better to weld on a number I can only just about manage to do straightish lines !
Post  Steve G on Tue Mar 17, 2015 8:27 pm
This is where it is, I had to rub the paint off to make it show up on camera.
Post  TRR Motorsport on Mon Mar 23, 2015 9:11 pm
I think I welded Robs back on after I replaced the top rail.
Umm, I think I'll have a go at tig welding the one into Pea. ;-)
