Mk 2 Rebuild.
Page 2 of 3 Previous  1, 2, 3  Next
Mk 2 Rebuild. - Page 2 Empty Re: Mk 2 Rebuild.
Post  iank on Thu Jun 12, 2014 10:30 pm
If you need more than £75 worth then metals4u's shipping is free. They also sell both metric and imperial tube which is handy.
http://www.metals4u.co.uk/mild-steel/box-section/products.asp?cat_id=49
As a tip it's always much cheaper to buy in 6m full lengths (from any supplier) than to have them cut it shorter lengths. So be ready with a new blade in the hacksaw on delivery day  Rolling Eyes
iank
iank
Number of posts : 10
Job/hobbies : Embedded Software Engineer / Kitcars, Electronics, Programming etc etc
Registration date : 2009-10-28
Post  Steve G on Thu Jun 12, 2014 11:13 pm
Thanks I will have a look round a bit more and see what I can come up with.
Post  Ferretboy221 on Fri Jun 13, 2014 7:02 am
Andrew maclean did mention that it is getting harder to find stockists who will supply the correct imperial box section without having to buy in bulk especially with the j channel for fold down windscreens apparently.
Post  Steve G on Sat Jun 14, 2014 11:29 pm
I have been trying to think of some ways to strengthen up the subframe mounts. I have seen a few pictures of MK2 engine bays showing some extra tubing.
Mk 2 Rebuild. - Page 2 Empty Mk2 Scamp Chassis
Post  red_leader on Sun Jun 15, 2014 5:38 pm
Its a good plan to weld in some diagonals from the front subfame bolts up to the top side boxes.
The Mk3 had these as standard.
View user profile http://www.scampownersclub.org.uk/
Post  Steve G on Sun Jun 15, 2014 9:04 pm
Looking at things a bit more there is quite a few places that could be made a bit stronger, depends on how much welding I want to do.
Post  Regsmonster on Mon Jun 16, 2014 8:21 am
Diagonals between top and bottom rails definitely stiffen them up (a roof helps as well)!
http://homepage.ntlworld.com/trr-developments/images/arse.jpg
Post  Steve G on Mon Jun 16, 2014 11:30 pm
I did a bit of welding today. The area around the bumper mounts was a bit damaged. I manaed to knock some of the dented area out and let in a couple of bits where I couldn't get to it properly. A bit of paint and it looks a little better.
Post  Mk3rob on Tue Jun 17, 2014 3:11 pm
Not wanting to perhaps state the obvious,
but have you jigged your trailer/Scamp with a spirit level to make sure your repairs aren't twisted Question
Post  Steve G on Tue Jun 17, 2014 5:15 pm
Hi Rob, I have set the Scamp up so it's level at the front and it's just sitting on a single point in the middle at the rear. It's all quite bent so I am trying to sort the front out first to what I know hasn't already moved. Bit of a job knowing where to start really.
Post  Steve G on Thu Jun 19, 2014 6:17 pm
The better of the two subframes had damaged mounting so I had to tap them put and fit helicoils.
I did this to get them square.
Post  Steve G on Mon Jun 23, 2014 9:22 pm
Now it's got some thread again.
Post  Steve G on Thu Jun 26, 2014 2:27 pm
This is about the height I want it to sit at. I will have to raise the rear arches to allow some suspension travel at the back though.
Post  TRR Motorsport on Thu Jun 26, 2014 10:03 pm
I can't wait to see this. I've never seen a low rider MK2 :-)
Post  Steve G on Fri Jun 27, 2014 12:33 am
It's going to be quite a bit of work to get it all to work properly. I plan to raise the subframe up in the chassis by altering the mountings. It will also involve moving the steering rack upwards and moving the steering column as well.
Post  Mk3rob on Fri Jun 27, 2014 6:45 pm
My Mk3 set up allows removal of the steering rack without disconnecting the sub frame like normal minis.
Are you going to affect this?
Post  Steve G on Fri Jun 27, 2014 9:01 pm
Not sure yet, what's the difference with the MK3 ?
Post  Mk3rob on Fri Jun 27, 2014 9:08 pm
I think its more to do with the extra wheel arch space than anything else.
Post  Steve G on Fri Jun 27, 2014 10:44 pm
I'm not sure yet. Hopefully I won't be needing to change it once it's on there.
Another thing I have been wondering about what colour to paint it although it's a bit early for that really. I was thinking about satin green but that seems quite popular already. I have seen pictures of a Moke painted in Gulf Porsche colours that looked quite good.
I think I have a name for it. Freddy as in Camp Freddy due to the fact that it's slightly bent !
Post  OSR on Sun Jun 29, 2014 8:28 pm
Love the name! Are you going to paint him pink?
Post  TRR Motorsport on Sun Jun 29, 2014 9:03 pm
I can't fault anything that's Gulf coloured, even a Moke.
I found half a Tin of Gulf Blue paint last week left over from when we painted Pea (it must be 17 years old at least) so I painted the personnel door to my garage and stuck a spare Gulf sticker on it.   Laughing
Post  Steve G on Sun Jun 29, 2014 9:32 pm
I quite like this colour not sure if its green or brown though !
I might end up keeping it/him beige but a slightly darker satin or matt finish.
Post  Steve G on Mon Jun 30, 2014 8:29 pm
I found this picture whilst searching around.
It looks like it has a slightly different front subframe mounting and it's given me a few ideas.
Mk 2 Rebuild. - Page 2 Empty Mk2 Scamps
Post  red_leader on Mon Jun 30, 2014 9:16 pm
I hope this starts a Mk2 renaissance.
We need persuade James to get his Mk2 back on the road !
Post  TRR Motorsport on Mon Jun 30, 2014 9:25 pm
Well I'll be dismantling it this autumn, so that's a start.
The engine will end up in the mini and I want to do the fabrication work to the chassis over the winter. As its relatively cheap compared to bolting things on and I want to perfect my TIG technique on something.
