Scottish Scamp
Page 2 of 2 Previous  1, 2
Scottish Scamp - Page 2 Empty Scottish Scamp
Post  Minivanman on Sat May 03, 2014 9:19 pm
Not posted for a while, Scamp now MOT'd and taxed and road legal, trouble is, not sure if it's the big wheels and tyres but it doesn't like top gear on the open road.
Minivanman
Number of posts : 84
Scottish Scamp - Page 2 Empty Re: Scottish Scamp
Post  Ferretboy221 on Sun May 04, 2014 6:58 am
What engine does it have in?......when I first built mine it had a 998 A+ in it which I had tuned to cooper spec (55bhp) but it was originally from a city -E which meant it had a 2.95 final drive ....as you are describing with yours top gear was always a struggle with any kind of hill at all as I had 12 inch wellers on.... worth checking the final drive unless you know what it is any way?
http://www.guess-works.co.uk/Tech/engine.htm
link above is an engine number decoder.
Post  Minivanman on Sun May 04, 2014 11:42 am
The engine is a pretty unknown object, 998cc from whatever, was lying about in someones garage, would expect it to be fairly standard tune, revs freely enough and drives ok up through the gears, but has very little power on the open road.
Probably just cant cope with the bigger wheels
Minivanman
Post  Minivanman on Sun May 04, 2014 11:56 am
If the engine and box is standard, "Gussworks" has it with 3.105 diff.
Minivanman
Post  Mk3rob on Mon May 05, 2014 7:38 pm
When I got mine it had a 998 in it with 13" Wellers.
I thought it drove well until coming up behind another vehicle and had to ease of and then over take it was sluggish.
It turned out to be the advance / retard in the dizzie. It moved ok when checking the timing but was failing under pressure.
Post  Ferretboy221 on Tue May 06, 2014 8:18 pm
...I just moved on to and got addicted to 1380cc torque ..... Laughing
