Weird Light
+6
Adam
USAMilScamp
10 posters
Weird Light
So quick question. I have this light on my console above my speedometer. It only comes on and stays on when Milly is off. I've yet to trace the wire to where it goes due to behind the console there is the source of all the worlds nightmares of rats nest wiring. Anyone know what this may be? I'll post a picture soon.
USAMilScamp- Number of posts : 4
Job/hobbies : US Air Force, hiking, camping, working out, working on cars, friends.
Registration date : 2012-09-03
Re: Weird Light
Milly?
Does the lamp have one wire going to it (i.e. the other side grounded) or two?
Re: Weird Light
I think we need some pictures
If you have a classic mini round speedo like this
http://www.minispares.com/product/Classic/Gauges/Speedo/13H4442.aspx?1404&ReturnUrl=/search/classic/speedo.aspx|Back%20to%20search
then the light at the top is meant to be either Main Beam or Indicators depending on how old it is. However there's no telling how previous owners have wired things up. I wonder if it's meant to give the impression the car's got an alarm?
Sympathy on dealing with the rat's nest. Iain, my OH, has just about finished rewiring my MK2. Only taken 18 months but it is a thing of beauty, he's even done wiring diagrams
Re: Weird Light
When it comes to Scamp wiring.....either meticulously go through every wire & check where it goes.....or rip them all out & start again..
Mine has still got some original mini wires left in it....think the plug & cable on the wiper motor is still mini ! Everything else is either VW, Vauxhall or totally custom.
If your going to re-wire, make sure you've got every wire going to the right place, is routed the best route & is the right length...then & only then wrap it in tape or spira-wrap.
As i'm sure Ian (Mr OSR) will agree with me on, there's no job worse than unwinding spira-wrap just to add another wire to the loom. (I've used / wasted 25m of the blooming stuff - so far).
Another tip, if you can't get the correct colour of wire (ie blue with white strip) & decide to use another colour... either add cable markers at each end & create a new circuit diagram or at the minimum pencil in the new colours into your Haynes manual diagram.
80% of my loom is yellow wires, 20% black wires, with the remainder in blue, brown, green etc... & i've not done a circuit diagram yet...looks like an even bigger rats nest than when i started.
Oh & welcome to the mad house.
By the way, this forum thrives on pictures...any problems will usually get sorted out much quicker if you can upload some pics. (see sticky in New Members section)
Re: Weird Light
I found mini trunking useful when running cables to the rear, just pop of the lid when you want to add another cable
Re: Weird Light
Oh that's ok
I saw a post from someone in the US Air Force about a weird light and thought I was going to get probed.
Adam
Adam
Adam- Number of posts : 57
Job/hobbies : Land Rovers, Scamps
Registration date : 2011-02-16
Re: Weird Light
Re: Weird Light
65% of statistics are made up on the spot. Including this one.
Re: Weird Light
Adam wrote:Oh that's ok
Adam
ILMFAO!!!!!
https://www.youtube.com/watch?v=LS-h6ok6LcA
Re: Weird Light
Hi
It may be a strange concept but have you tried asking the previous owner?
Re: Weird Light
Considering i'm a mechanical designer, no maths isn't my strong point.
That's why £20k worth of CAD station is my tool of choice...makes stress anaylsis & force calculations a doddle. Don't even need to remember the Trigonometry i learnt at school.
Re: Weird Light
Dont forget your sliderule..................
..................Nah your to young, you would have used the devils tool................ the calculator
Re: Weird Light
I have a slide rule somewhere and where are my Logarithmic tables !!!! (if you don't like the light take the bulb out)
Re: Weird Light
nhazelwood wrote:Considering i'm a mechanical designer, no maths isn't my strong point.
SIN, COS, TAN and Piethagusarus' (is that a Dinosaur? It is now) theorum.
Oh the pain. I had to pay for extra maths lessons to get me through my HNC & now i can't remember any of it.
Re: Weird Light
As i learnt......Selly Oak Hospital (SOH) Can Amputate Hands (CAH) Toes Or Arms (TOA).
Fortunately i was taught "Old School Design", i had to learn how to use a slide rule & log tables before i was allowed to use a calculator in the Drawing Office.
The worst we had to do was helical & spur gear calc's. Everything had to be calculated by hand, Pitch circle diameters, addendums, dedendums, helix angles, involute angles & backlash angles.
To design a multi-spindle with 25 different tools running at different speeds, in fixed positions, all being driven off one motor, would take the best part of a week in calculations. My CAD system allows me to do the same thing in less than 1hr ! & i can see the spindles rotate on the screen to make sure they turn in the right direction...
Just goes to show £20k of CAD system & we still don't know what the lights for !!!!! Technology sheesh.
Re: Weird Light
Wonderful thing, technology. With a PC on my desk, I could waste more time in an hour than, twenty years earlier, I could in a week.
Re: Weird Light
Only just seen this, it has a LED lamp above the speedo, in the middle of the dash, it sort of looks like it has an immobiliser or alarm when the ignition is off, was there when I bought it! The wiring was a little untidy and hidden away but I've left it alone as it all worked
It can be seen here...
