For Sale -Superbeam! Chrysler Sunbeam Rally Car
1978 Chrysler Sunbeam Rally Car.
An edition to the family forces reluctant sale of my beloved Superbeam.
The car it turnkey ready for the 2009 season, 12 months MOT, current MSA logbook. Well built, simple and totally 100% reliable on events.
A competitive car on single and multi venue events. Notable results 1st in class, 2nd in class and 8th O/A (the driver is the handicap!) The car is class 3 but will out run and out brake most class 4 cars (2lts 4WD) on an open stage such as an airfield!
Many thousands spent (receipts to prove costs and spec)
Interested? Call James on 07501 680215
Specification
Engine
1998cc Vauxhall XE (Redtop) 198BHP at wheels (approx 220BHP at flywheel)
· Head ported & polished by Peter Burgess
· Piper 285H cams
· SBD Vernier Pulleys, Cam timing is exact!
· Omega pocketed pistons & ARB rod bolts
· MBE ignition
· balanced Twin 45 DCOE Carbs, matched inlet assembly.
· Lightened bottom end, flywheel, TDC disc removed from crank, alloy TDC pulley
· Paddle clutch
· SBD low level dry sump system c/w braided hoses and slimline oil tank
· NGK Platinum plugs
· Chassis mount kit
· Ashley 4-2-1 Manifold & modified system – 96db!
· Big core radiator and silicone hoses
Gearbox
Tran-X S/C Clubman ford type 9, 5 speed gearbox
· Quick shift gear stick
· SBD bell housing
· Balanced prop shaft.
Axle
Sunbeam axle
· 4.4CWP
· Mal Stuart plate LSD setup for tarmac
· TRR axle brace fitted
Suspension
· Front -Leda struts with 210lbs springs
· Rear – 240lbs springs & Gaz shocks
· Neg camber crossmember
· Braced trailing arms, drag links & links.
· Kazbarn 2.4 ratio steering rack with braced steering arms.
· Fully polybushed
Brakes
· Front – Wilwood Dynalites & Poly E pads
· Rear- XR3 calipers, standard pads
· Hydraulic handbrake
· Goodridge hoses all round
Body
· Fully seam welded and strengthened
· Safety Devices FIA cage 10 point cage
· Arched body
· GRP wings & bonnet
· Motordrive roof vent
· Sump guard
· Bespoke alloy tank and O’Kane polypropylene guard
· Twin red top fuel pumps
· Bronze tint polycarbonate windows
· GRP light weight flocked dash & carbon fibre door cards
· Full RCD wiring – no fuses!
· OMP suede steering wheel
· Motordrive GRP Pro 2 & Pro 3 seats with Luke harnesses (in date till 2010)
· Handheld and plumbed in extinguishers
· Revolution 8” x 13” four spokes on 200x530x13 tyres
Specification
Engine
· Piper 285H cams
· MBE ignition
· Paddle clutch
· Chassis mount kit
Gearbox
· SBD bell housing
Axle
Sunbeam axle
· 4.4CWP
Suspension
· Fully polybushed
Brakes
Body
· Arched body
· Sump guard
minislapper- Number of posts : 296
Job/hobbies : Job: Education - Hobbies: minis, motorsport and things on 4 wheels in general
Registration date : 2008-05-16
Re: For Sale -Superbeam! Chrysler Sunbeam Rally Car
"addition to the family"...? Did I miss something?
Shame you have to sell your car.
Jono wrote:"addition to the family"...? Did I miss something?
I might yet change my mind but the capital it would free up could help out right now.
Minislapper, The old girl is on a few forums at the moment but i gave up with the British Rally Forum a couple of years ago. There are some good guys on there but it's mostly muppets that seam happy to offer an opinion on subjects they have no knowledge about. How can you comment on the condition of stages of errors in road timing if you didn't compete on the event?
If I were you James I'd keep The Rally Beam in the current climate, it's a classic so its value will only go up (in the long term)....... Sell the Golf instead.
Elaine.
Elaine.
"The old girl" What about the car
One less car to shuffle around, what will you do with all the spare time?
Oh yeah
Oh yeah
» £110,000.00 FOR A 1982 TALBOT SUNBEAM????
» And now i'm really kicking myself for selling the sunbeam.
» James's beloved Sunbeam
» But there's always another project!
» Stourport steam rally july 2011
