» Any takers - convert your Scamp
by Mk3rob Tue Apr 17, 2018 1:47 pm
» Mk2 on Ebay Q***ANJ
by Rum Tum Tugger Tue Apr 17, 2018 8:45 am
» Mk2 on Ebay - Essex
by Mk3rob Sun Apr 15, 2018 2:09 pm
» NOS Spitfire fuel tank for sale
by Rum Tum Tugger Tue Apr 10, 2018 7:50 am
» LAUGHTON SHOW
by wezgit daan saaf Fri Apr 06, 2018 5:31 pm
» Garden find
by Rum Tum Tugger Wed Apr 04, 2018 4:33 pm
» Coffee / Tea debate
by Rum Tum Tugger Sat Mar 31, 2018 8:17 am
» New MoT rules from May 08
by Mk3rob Thu Mar 29, 2018 10:30 pm
» Mk3 project oop norf
by Rum Tum Tugger Thu Mar 29, 2018 9:58 pm
Mini Sport Smootha Rides
Post  SUMB on Mon Feb 14, 2011 9:21 pm
I have to say what a revelation these new front cones are woohoo. The Scamp now has supple front suspension bounce Just wish I could say the same about the rear Mad
I must thank Steve, president of Bomber County Minis and owner of Tyre and Tech here in Lincoln, for all the help getting these fitted. Without his guidance and ingenuity I would be sitting in the corner of the Tyre & Tech workshop sucking my thumb, rocking back and forth and waiting for the men in the white coats to come and fetch me. weeping
As a word of warning for anyone else looking to fit the Smootha Ride cones - Do not attempt this without a cone compressor. Unlike standard cones with Hi-Lo's the Smootha Rides must be compressed to get the top arm back in place and fit the spindle bar. Luckily I decided to take my cone compressor with me up to the workshop Very Happy
Unluckily though, for me, a previous owner of the Scamp had replaced the chassis rail that the sub-frame towers bolt to and forgotten to re-drill the centre hole that the compressor tool passes through scratch I am so glad Larry didn't bring his young son, Jacob, as he may have gone home with some extra words in his vocabulary nono
So my message to the BCM guru is
bow bow bow bow bow
Un-numb Bum
Post  Mk3rob on Tue Feb 15, 2011 12:01 am
Ok, so what was the price of this smoother rde Twisted Evil
Number of posts : 2289
Re: Mini Sport Smootha Rides
Post  SUMB on Tue Feb 15, 2011 9:01 am
90 of her majestys pounds. Picked up the bits from the Bingley Hall show the other week. Got the cones for 70 quid for the pair and then 40 quid for a full set of Hi-Lo's, but as I only wanted the fronts I sold the rears to one of the lads in the Mini club for 20 as he just wanted a set of rear Hi-Lo's.
Obviously now wishing that I had kept all of them as I would like to try the Smootha Ride cones in the rear too.
Post  nhazelwood on Sun Feb 20, 2011 12:14 am
I've just bit the bullet too chaz...
Ordered a pair of rear smootha ride cones (30+vat each from Minisport).I'll see what they're like before I try my hybrid versions out.
Having just set up the front ride height & fitted the new adjustable bottom arms & tie rods, I want a couple of weeks off from the front suspension.
Managed to tweak my subframe mod's out & got both sides to 1deg neg camber, 2deg castor. (passenger side was 6deg pos camber & 14deg castor...no wonder walle wanted to dive into the hedge all the time.)
Just got tracking to sort out tmrw today.
Oh & also stop the drivers side wheel from spining when I go round islands (bl@@dy torque steer).
Anyone tried balance weights on long driveshaft to get rid of torque steer (like modern cars) ?
Post  nhazelwood on Sat Feb 26, 2011 9:11 pm
Just a quick update...
Rear Smootha ride cones from MiniSport turned up on tuesday morning.....woohoo...unfortunately has been a week from hell at work (from sat night to friday worked 85hrs), so had no time to try the puppies out.
Today the munchkin let me spend an hour of our time together fitting them...result.
Only done about a 60mile run to Coventry & back, but....what a difference Shocked
The kangaroo back end has totally gone. Very Happy Yes you can still feel big bumps, but normalish road bumps feel significantly smoother. Driving over the same roads i drive every week & knowing every bump painfully well, i'm very impressed with the ride.
I noticed the same thing as Chaz with the front cones, the rears are about 20-25mm longer than the original cones.
(The original cone looks funny because the metal cup is only dropped back in, it parted from the rubber getting it off the hilo)
By winding the hi-lo down to its shortest length the cone will just fit into a mark 2 scamp without using a cone compressor. I found that the threaded adjuster (Minisport Hi-lo cones) sticks just past the ally casting & required a quick trim off with a hacksaw (about 2mm cut off). This just leaves the circlip in place & allows the hi-lo to slide into place.
Altogether a noticable improvement.
(Just need to have a little play around some islands on the way home from work tonight to check out how the back end behaves. After a play on monday night with the old cones, i've struggled to get the back end to break out in the wet, but quite a bit of understeer as the drivers side wheel starts to spin in 3rd gear!)
Will update when i've bedded the cones in a bit.
RE: Mini Sport Smootha Rides.
Post  GT3Rob on Sun Apr 17, 2011 10:06 am
H i I was Looking at this set up for mk3 and i was informed that although the fronts are soft, the rears in the kit are standard.
is this the case and if extension brackets are used for 13" wheels on the scamp what type of cone is required for the rear? New soft, standard or comp?
Do the new smootha rides fit a standard hi low/adjusta ride cone/trumpet??
GT3Rob
Number of posts : 153
Post  nhazelwood on Sun Apr 17, 2011 10:43 pm
Hi Rob,
The cones I bought are the Moulton Smootha Ride ones from mini-sport.
They are only available in one hardness, but have a slightly different shape to the normal mini cone.
By being slightly longer & a different shape, they are supposed to be a more progressive spring rate.
Although the mini-sport website says you have to use the Moulton Adjusta-Ride version of the hilo, I'm using the cheap as chips mini-sport cast hilos & they fit & work fine.
After 800+ miles I'm very impressed with the rears. Saving up for a set for the front now.
